Date/Time: Tue, 07 May 2024 15:50:51 +0000
Market replay
View Count: 910
[2014-05-12 08:06:53] |
User81127 - Posts: 15 |
Hi SC, is there any option to replay charts also in different chartbooks? Meaning I have 3 opened chartbooks with different timeframes and indicators and I would like to see them all replaying simultaneously. Thank you for your advice. Jiri |
[2014-05-12 08:22:51] |
It is possible to have charts in different Chartbooks replaying at the same time, but they have to be started separately for each Chartbook. And you can only have one Chartbook visible at a time. Although chart windows can be shared across Chartbooks with Window >>Window Always Visible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-12 08:27:34
