Date/Time: Sun, 05 May 2024 22:28:50 +0000
Attached orders - keep fixed RRR
View Count: 1027
[2014-05-11 10:11:07] |
VF56002 - Posts: 27 |
I would like to know if following scenario is possible in SierraChart: Let's say I enter a trade with SL set to 8 ticks and PT set to 9 ticks. I reassess SL position and move it to 6 ticks. As I want to keep strictly the same Risk-to-Reward my PT should be now at 7 ticks from entry (RRR always 1:1 + 1 tick). Is it possible to set SC to move my PT automatically according to SL adjustments? Sometimes market is quite fast and before I manage to move my PT closer, market comes closer and bounce back before fill .. If it's not possible, would it be difficult for the developers to add this function? Something like "Keep same RRR for attached orders" checkbox Thank you Date Time Of Last Edit: 2014-05-11 10:12:04
[2014-05-12 17:40:16] |
No, this is not supported. If we were to add this, it would not be for a while. We have too many other things to do ahead of this.
[2014-05-12 19:17:46] |
Futures Operator - Posts: 239 |
You could try using keyboard shortcuts to move both the stop and target very quickly.
[2014-05-12 21:33:25] |
Solved it using ACSIL :-)
