Date/Time: Sun, 05 May 2024 17:53:47 +0000
cannot select 5 second timeframe on Rithmic feed
View Count: 1217
[2014-05-10 14:28:41] |
janos bardon - Posts: 37 |
Hello, I switched from TT FIX to Rithmic feed (SC), but I have the following problem: connection OK i must select new symbol (CLM4-NYMEX instead of CL-201406-CME) but on the new chart the least time frame is 1 minute, if I select 5 or 30 second it displays only the 1 minute chart, but I need a 5 second chart too, is this not possible anymore with Rithmic? Regards janos |
[2014-05-10 18:50:36] |
Hendrixon - Posts: 130 |
Check the connection config. You probably have it setup to save data at 1 minute granularity. For 5 seconds bars set it to 5 seconds or less, and if you need tick bars or volume bars or any bid/ask analysis than set it to 1 tick. |
[2014-05-10 19:59:20] |
Hi Hendrixon, I cannot find the connection config. where is it? regards janos |
[2014-05-10 20:03:59] |
Rithmic provides only 1 minute Historical data. Refer to this page: http://www.sierrachart.com/?l=doc/Rithmic.php#Included Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-11 03:27:25] |
OK thank you, then this is not for me
[2014-05-11 06:52:53] |
We just realized that the Rithmic page previously indicated this: Historical BidVolume and AskVolume: Yes. This is not correct, it is No. We have corrected the page. It is only Yes when using Rithmic through Optimus Futures: http://www.sierrachart.com/index.php?l=doc/OptimusRithmic.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-11 06:53:18
[2014-05-11 07:29:20] |
Thank You, may I ask You, which broker is providing SC with TT Feed without the data is delayed by 10 minutes upon connection to the data feed? (Crossland unfortunately not anymore) Regards Janos |
[2014-05-11 07:55:54] |
VF56002 - Posts: 27 |
janos bardon: I trade 30s chart with Rithmic and Crossland. They have real-time tick data but there are no historical tick data I was also happy with TT, but couldn't find same setup TT FIX + SC :-) TT have solved calendar spreads very well for example ... Date Time Of Last Edit: 2014-05-11 07:57:13
[2014-05-11 08:53:23] |
Thank You, may I ask You, which broker is providing SC with TT Feed without the data is delayed by 10 minutes upon connection to the data feed? (Crossland unfortunately not anymore) AMP futures.
