Date/Time: Mon, 29 Apr 2024 17:15:28 +0000
Order fill marker
View Count: 1336
[2014-05-09 20:02:40] |
mattb - Posts: 30 |
Can the order fill marker be customized? Would like to increase the size, and or color of the markers on chart. thank you |
[2014-05-10 03:05:22] |
Yes. Refer to the documentation here for this: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
