Date/Time: Mon, 30 Jun 2025 20:43:49 +0000
Cannot change Spreadsheet study graph draw type
View Count: 523
[2022-08-05 23:15:31] |
toews&kane - Posts: 209 |
Hi, I am inserting values into the spreadsheet wanting to plot as a line. However, when I go to the subgraph it locks the default to "Candlestick Bars" as the graph draw type. Also, the draw style I only see Visible orIgnore. I see from the documentation that I should be able to see different draw types line, stair step etc, Using the Spreadsheet Study Please advise |
[2022-08-06 08:36:53] |
Sierra_Chart Engineering - Posts: 20025 |
Currently the way this works is that the Graph Draw Type for the Spreadsheet Study will be the same as the Main Price Graph: Chart Settings: Graph Draw Type (Chart >> Chart Settings >> Bar Period >> Graph Draw Type menu) In the next release you will be able to set the Graph Draw Type independently for the Spreadsheet Study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-06 08:39:55
