Date/Time: Sat, 18 May 2024 17:30:31 +0000
Zone to track with price
View Count: 969
[2014-05-09 15:05:15] |
TraderTom - Posts: 25 |
I use Extended Rectangles for price trading zones, and label them with text. I keep the text stationary in the right side fill space, but they need to track with the zones as the price changes. How can I attach text to a zone but still stay in the fill space horizontally?
[2014-05-09 16:54:30] |
It is now possible to add custom text to the Extending Rectangle drawings. Here is the documentation for this: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ModifyText Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-09 16:56:05] |
You will need to update Sierra Chart to the latest prerelease to make sure you have this feature.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-09 17:00:45
