Date/Time: Sat, 18 May 2024 08:43:59 +0000
Save DOM graphic settings
View Count: 2309
[2014-05-09 07:42:25] |
User96267 - Posts: 43 |
Dear SC-Team, I want to save my Trading DOM Settings withing Sierra Chart. Everytime I finish the graphic settings of one DOM and open another one, it has the old graphic style. How can I fix that? Is it possible to set my individual graphic settings to all DOMs? Thanks in advance and great work you provide. Max |
[2014-05-09 07:44:43] |
Yes. You need to do the settings through Global Settings >> Graphics Settings. You may also want to duplicate a Trade DOM with Chart >> Duplicate Chart so the new one gets the same settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-09 08:59:48] |
Great, thank you. That's what I was looking for. Furthermore, there are 5 Ask and 5 Bid levels displayed in the DOM. Is it possible to extend it to 5 more levels? So for example the market depth from 9510-9530? Thanks in advance. Max |
[2014-05-09 09:44:07] |
This depends upon the particular Data or Trading service you are using and the Symbol. We cannot answer the question without that information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-09 10:12:49] |
It is AMP/TTNet. Thank you for your great support. |
[2014-05-09 16:01:56] |
You can modify the maximum number of depth levels through Global Settings >>Data/Trade Service Settings. After changing that setting, you need to reconnect with File >> Disconnect and File >> Connect to Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-09 18:11:30] |
Thank you very much. Problem solved. Have a nice weekend! |
