Date/Time: Sat, 04 May 2024 07:05:08 +0000
[User Discussion] - disable auto trading not working
View Count: 991
[2014-05-09 05:14:19] |
toews&kane - Posts: 209 |
Hi there, This cell is not effectively holding the disable auto trading. Is there something else that can do this? My code in cell J28 to lock in no trading is: =AND(OR(J41-INT(J41)<TIMEVALUE("08:45:00"),J41-INT(J41)>TIMEVALUE("15:00:00"))) but it entered at 16:08 screenshot attached. Greatly appreciately if we can figure out why this is entering when the cell has locked trading. I have just opened Sierra chart if and it auto traded with a buy position. That's the only thing I am facing currently, thank you. |
Capture.PNG / V - Attached On 2014-05-09 05:11:50 UTC - Size: 208.66 KB - 326 views |
[2014-05-09 05:18:52] |
We cannot help with the formula but we recommend that you enable Trade >>Disable Auto Trading on Startup
[2014-05-09 11:27:19] |
sbsierra - Posts: 71 |
You want trading to enabled from 8:45 till 15:00, right? Use: =OR(J41-INT(J41)<TIMEVALUE("08:45:00"),J41-INT(J41)>TIMEVALUE("15:00:00")) I would recommend to use another cell to disable autotrading via a filter condition and use the output together with a entry condition. Then it is still possible to use the exit cells, if e.g. a trade ist entered at 14:58. regards, bs.trader |
