Date/Time: Fri, 03 May 2024 13:21:11 +0000
Order entries
View Count: 1877
[2014-05-08 20:23:45] |
George - Posts: 60 |
Is there a way to enter a Buy Stop-Limit order and have an attached Sell Stop with only one click or one button to press?
[2014-05-09 04:44:13] |
Yes. We recommend using the Chart DOM: https://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#ChartDOM And you will need to use Attached Orders: https://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
