Date/Time: Fri, 13 Nov 2026 21:50:30 +0000
[User Discussion] - installing SC on AWS win server
View Count: 1167
| [2022-07-29 12:41:29] |
| User61576 - Posts: 458 |
few questions: 1. what will be a good / enough VCPU for scalping based on 10 seconds bars (tick-based) assuming running 4 cht with each 4-5 charts? 2. nearest location to CME is east2 (Ohio). what latency should I expect? 3. can I copy my SC settings from my local PC to that win server and it will work? 4. if I don't save tick data there, is there any need for that SSD drive? any other tips from your experience will be much appreciated! |
| [2022-08-07 10:28:29] |
No one knows?
| [2022-11-13 01:21:18] |
| Jim_M - Posts: 8 |
I’m thinking about the same thing - installing my SC on an AWS server but I also have no idea what the specs should be to ensure that it runs well. If there’s no info here I think I’ll have to do some trial and error. If I can get it working well, I will post my info.
| [2022-11-13 15:41:20] |
I haven't done this also so your trail/error will be very much valued.
| [2022-11-13 20:34:48] |
| Sierra_Chart Engineering - Posts: 25422 |
Yes you can: 3. can I copy my SC settings from my local PC to that win server and it will work? As far as what you require from a virtual machine, you just have to make your own determinations. But It should be at least 6 fast cores, with 16 GB of memory and hundreds of gigabytes of solid-state storage. A dedicated server would be better though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-13 20:35:03
