Date/Time: Sat, 18 May 2024 22:27:09 +0000
market profile
View Count: 432
[2022-07-28 07:20:27] |
User220939 - Posts: 34 |
Bonjour, J'ai fait la mise à jour hier et depuis j'ai un problème sur le market profile. Je trade le dax, et mon étude market profile qui ouvre 2h15 commence sur la lettre E. J'ai une autre étude market profile qui ouvre à 9h00, et sur celle la ça commence bien avec les A. Je n'arrive pas à trouver d'où vient le problème. Merci |
[2022-07-28 16:34:16] |
From Google Translate: Hello,
I made the update yesterday and since then I have a problem on the market profile. I trade the dax, and my market profile study, which opens at 2:15 a.m., begins with the letter E. I have another market profile study that opens at 9 a.m., and on this one it starts well with the A's. I can't find where the problem is coming from. Thanks Refer to the following: Time Price Opportunity (TPO) Profile Charts: Starting Letter and Session Start Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-10 09:16:08] |
Guelvyn - Posts: 1 |
Bonjour, sur mon Market Profil du Dax quelle valeur est-ce que je dois mettre sur le paramètre : "Letter/block Price Increment Ticks"
[2024-04-10 16:04:18] |
From Google Translate: Hello, on my Dax Market Profile what value should I put on the parameter: “Letter/block Price Increment Ticks”
This is a personal decision and not something we can really answer. Refer to the information for the "Letter/Block Price Increment in Ticks" for an understanding of what this does: Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
