Date/Time: Thu, 02 May 2024 03:25:07 +0000
Drawing on multiple charts simultaneously
View Count: 2269
[2014-05-08 15:58:44] |
User80868 - Posts: 4 |
Hi there please could you tell me if is possible use some tools on variuos charts at the same time I want to draw some extended rectangles on different charts Thanks for your help |
[2014-05-08 16:54:15] |
Yes. You simply need to activate the chart that you want to use the Tool on. Or did you want to automatically copy a chart drawing from one chart to another? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-08 18:13:06] |
Yes, I want to copy automatically from one chart to others. Thanks |
[2014-05-08 18:16:45] |
looking_afar - Posts: 17 |
Chart properties (F5) > Advanced Settings 2 > Copy chart drawings from Chart # You need to insert the number of the chart you want to copy drawings from. There was a good description somewhere in the manual. |
[2014-05-08 18:24:29] |
Refer to: https://www.sierrachart.com/index.php?l=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
