Date/Time: Mon, 06 May 2024 08:06:51 +0000
stop-limit order not working
View Count: 1067
[2014-05-08 15:51:36] |
User99576 - Posts: 7 |
Hello I have got a problem with a stop-limit order, I’m trading with chart DOM and I checked at the MENU to use a stop-limit order instead of stop order. But it seems doesn’t work and it is simple stop order and I’m getting slippages, if you can help , best regards Software version: 1132 | 2014-05-08 15:01:09 Date Time Of Last Edit: 2014-05-09 03:34:57
[2014-05-09 03:36:14] |
We have tested this and we do not see a problem. Make sure you have enabled Use Stop-Limit Orders on Chart DOM on the Trade Window for the chart that you are trading from. To open it select Trade >> Open Trade Window for Chart. For more information refer to this section here: https://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#ChartDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-09 03:37:24
