Date/Time: Tue, 07 May 2024 13:01:15 +0000
data question...
View Count: 879
[2014-05-08 02:16:58] |
User53765 - Posts: 66 |
Hi Support, As per the Sierra real time data section Im quoting reference ``•When the CME data feed is made available with exchange fees, you will be able to get both historical and real-time data independent of a trading account.`` Can you please tell me when this offer will be available approximately from todays timeframe and also will the ES futures contract be part of this offering or CME products in general? Thanks in advance. |
[2014-05-08 03:35:48] |
We need to update the documentation. The CME data feed will not be made available to be used separate from a trading account and at the standard exchange fees. So this will not be available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-08 07:18:39
[2014-05-08 07:18:54] |
There was a dictation error in the prior response. This is the correction: We need to update the documentation. The CME data feed will not be made available to be used separate from a trading account and at the standard exchange fees.
