Date/Time: Tue, 07 May 2024 08:12:06 +0000
Reversal bar charting
View Count: 967
[2014-05-07 16:02:00] |
User93534 - Posts: 30 |
Is it possible to make reversal bar chart by candlestick or numbers bars that has a range set higher than reversal bar period? I want a 4 tick reversal bar but set to a 6 tick minimum range. Thanks in advance. |
[2014-05-07 17:22:23] |
No, this is not supported.
