Date/Time: Sun, 05 May 2024 18:26:07 +0000
Visual NYSE Tick alert
View Count: 1135
[2014-05-07 13:31:03] |
Dom7364 - Posts: 257 |
IS there a way to display a visual alert if the NYSE Tick chart reaches a certain level? It could be a vertical highlight of the bar that reaches the defined level, or a dot, an arrow above/below the bar etc. The idea would then be to have this automatically displayed onto another chart..Or perhaps an easier way would be a way/study, that checks another chart level and display on the current chart a highlight/dot/arrow/etc..? Thanks |
[2014-05-07 17:38:31] |
Yes. This can be done with the Color Bar Based on Alert Condition study: https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s245 You can overlay studies from one chart onto another chart. This is documented here: https://www.sierrachart.com/index.php?l=helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-08 14:52:51] |
How can you set the alarm to remain: For example if I have a coloured background alert, how to set it up so it stays on the chart? an doesn't dispappear once the level defined is not crossed over any longer?
Date Time Of Last Edit: 2014-05-08 15:41:59
[2014-05-08 19:06:20] |
This would require custom programming. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html We cannot provide specific details about how to do this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
