Date/Time: Thu, 15 Oct 2026 00:13:48 +0000
I am having trouble connecting to data feed.
View Count: 682
| [2022-07-09 08:29:22] |
| User672038 - Posts: 2 |
I keep getting an error regarding connecting to my data feed. Can you check for me please?
| [2022-07-09 08:29:35] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
