Date/Time: Thu, 15 Oct 2026 00:13:23 +0000
Seroius bid ask volume lag in fxcm and morningstar forex data
View Count: 1008
[2022-07-08 15:20:54]
User447007 - Posts: 44
I sarted to watch chfjpy at 10 am, where there was no volume spike at 8:40 . I used fxcm data. ( I attached picture)
The chart remained the same at least for 30 minutes. Than I opened another pair in that window ( in watchlist mode)
and when i reopened chfjpy the chart showed a big volume spike, 2 hours earlier at 8:40 am.
I also checked later in morningstar database, where 2 hours later there was no volume spike at all!! ( attached)
I know that you calculate that bid-ask volume, but what time does it take for you, and what could
cause that kind of divergency, as this spike is a seroius difference.
https://www.sierrachart.com/image.php?Image=1657292979430.png
https://www.sierrachart.com/image.php?Image=1657293501963.png
imagefxcm.jpg / V - Attached On 2022-07-08 14:58:23 UTC - Size: 119.09 KB - 308 views
imagemorningstar.jpg / V - Attached On 2022-07-08 14:58:40 UTC - Size: 119.95 KB - 319 views
[2022-07-09 08:37:54]
We are not understanding this. And furthermore, the data for these data feeds is passed through as it is received from the source feeds (FXCM and MorningStar). We do not have any control over that data.
If there is any incomplete data, re-download the data:
Make sure you are not using any volume filtering:
Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu)
Date Time Of Last Edit: 2022-07-09 08:42:23
