Date/Time: Sat, 04 May 2024 12:12:52 +0000
Dual Brokers ?
View Count: 944
[2014-05-07 08:57:31] |
Yes this is supported but you need to have a direct Sierra Chart account: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html You will need to install one copy connected to your Infinity/TransAct account and another copy of Sierra Chart connected to another Trading service like Interactive Brokers. Refer to this page for instructions: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html As far as stock-option goes, among the services supported by Sierra Chart we only know of Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
