Date/Time: Sat, 04 May 2024 05:39:40 +0000
IQFeed Historical Intraday Data Option Gone in V1133
View Count: 986
[2014-05-06 12:03:06] |
xfighter - Posts: 36 |
I just update to version 1133 and the IQFeed Historical Intraday Data option is gone. Does that mean now we only have the tick data not 1 minute data any more? Thank you! |
[2014-05-06 17:16:57] |
The way this works is documented here: https://www.sierrachart.com/index.php?l=doc/DTNIQFeed.html#RulesDownloadingData We did not see a real purpose to keeping the option any longer with the way that this works in 1133. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
