Date/Time: Wed, 30 Sep 2026 19:57:34 +0000
Draw median of ON high and low?
View Count: 719
| [2022-07-03 22:11:21] |
| 58LesPaul - Posts: 429 |
Is there a study that will draw a line at the median of the overnight high and low? Thanks |
| [2022-07-04 10:31:58] |
Use this study: High/Low for Time Period - Extended And then use the Study Subgraphs Average Study: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
