Date/Time: Wed, 01 May 2024 01:53:40 +0000
Updating Symbol Settings
View Count: 977
[2014-05-06 06:11:58] |
User29511 - Posts: 19 |
My charts open with a notification to "Update Symbol Settings" using the "Full Reset" button. 1. Will doing this affect any of my charting settings as it appears to over-write everything? 2. Are there any precautions I need to take first to ensure I don't have any problems? Thank you for your assistance. |
[2014-05-06 06:46:22] |
1. Performing a Full Reset of the Global Symbol Settings will not affect the existing Chart Settings. 2. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
