Date/Time: Sun, 05 May 2024 19:13:22 +0000
Is it possible? ... Trading Scripts to place order on previous bar high/low
View Count: 1256
[2014-05-05 23:49:44] |
JP - Posts: 24 |
I am fairy new to sierracharts and wanted to know if it is possible to create a script that when executed will place an entry order 1 tick above or below the previous bar. I appreciate your guidance on this Thank you |
[2014-05-06 01:48:40] |
Do you want to place a Limit order one tick above or below the previous bar? If so, yes this is supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-06 01:56:58] |
JP - Posts: 24 |
I want to place a stop order one tick above/below the previous bar to go long/short Where could I learn to do this? is there any documentation? Thank you |
[2014-05-06 03:03:44] |
Yes this can be done. This can be done using Spreadsheets or ACSIL. This is a good starting page: https://www.sierrachart.com/index.php?l=doc/doc_AutoTradeManagment.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
