Date/Time: Sun, 05 May 2024 18:25:19 +0000
adjusting volume profile
View Count: 1035
[2014-05-05 20:01:35] |
User30743 - Posts: 364 |
one more thing with the volume - when i want to adjust a volume profile that covers several swing, it doesnt work. instead of adjusting it still stays the same. and some lines appears when i click right mouse. but the volume profile cannot be enlarged. could you tell me what the problem with the adjusting is? viz the screen Date Time Of Last Edit: 2014-05-05 20:03:55
adjusting vol.png / V - Attached On 2014-05-05 20:01:31 UTC - Size: 64.33 KB - 310 views |
[2014-05-05 21:54:04] |
Do the following: Update Sierra Chart to the latest release. Remove the Volume by Price studies on the chart that were drawn with the Draw Volume Profile tool and draw them again. They should work fine after that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
