Date/Time: Mon, 06 May 2024 12:06:08 +0000
daily volume by price - setting
View Count: 1349
[2014-05-05 18:23:39] |
User30743 - Posts: 364 |
hello, is it possible to somehow fix price action LEFT SIDED from the daily Volume by Price? i know there is a function LOCK FIL SPACE but it locks both the price action and the Volume by Price from the right line. i need them to be separated so that i could see the price action.. viz screenshot Date Time Of Last Edit: 2014-05-05 18:32:11
Attachment Deleted. Attachment Deleted. Attachment Deleted. Attachment Deleted. |
[2014-05-06 17:24:24] |
Yes this is possible and it is documented here: https://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#RightAligning Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-07 12:43:07] |
well, ok, but this is not actually what i need because i DO NOT use single profile but MULTIPLE VOLUME PROFILEX FIXED BY TIME (DAY AND NIGHT SESSIONS SEPARATED). i know it is possible to make it this way on the SINGLE PROFILE, but i would need it my Multiple Profiles as well.. is it possible? Date Time Of Last Edit: 2014-05-07 12:43:34
[2014-05-07 17:14:54] |
The instructions are still valid. What you need to do is add space on the right side of the chart and this is specifically documented here: https://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ScrollingTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-07 21:04:13] |
mmmm... either i am totaly stupid or you dont understand what i mean.. the point is when i move the chart to the left, it moves WITH the daily volume profile - http://www.sierrachart.com/image.php?l=1399496763445.png this is how it looks withouth daily volume profile when i move it left - http://www.sierrachart.com/image.php?l=1399496827391.png - and i wished the daily volume profile were fixed at the right line just as it is when i use one single volume profile (that is set as VISIBLE BARS) - http://www.sierrachart.com/image.php?l=1399496968293.png but i cant make it possible with volume profile that is set as MULTIPLE PROFILES FIXED BY TIME where the days and nights are separated, just like here - http://www.sierrachart.com/image.php?l=1399496763445.png so.. am i so stupid? Date Time Of Last Edit: 2014-05-07 21:10:24
[2014-05-08 19:23:51] |
We have looked into this. And the documentation missed one setting. It has been added and updated here: http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#RightAligning Be sure to reload that page in your browser for the updated documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-08 19:58:31] |
perfecto!! bellisimo
[2014-05-11 11:35:07] |
User33737 - Posts: 8 |
User30743, I am wondering how you placed those numbers at the lows and highs of the number bars on your charts. I tried the setting for Value on High but it places it over the highlow of the number bar and is not readable. thanks very much |
[2014-05-11 16:49:42] |
it is pullback. set the pulback on your bar chart and you will see them as i do
[2014-05-11 16:54:52] |
thank you
