Date/Time: Fri, 03 May 2024 04:33:24 +0000
TICK-NYSE not working (ticksp working fine)
View Count: 1082
[2014-05-05 13:47:59] |
Joe Hobart - Posts: 89 |
looks like something is jammed on the nyse tick. sp500 tick working ok
[2014-05-05 15:20:09] |
This problem is now resolved. You should be getting data now. A solution that would have worked would have been to select File >> Disconnect and File >> Connect to Data Feed. The problem affected one server. So not all users were affected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
