Date/Time: Fri, 03 May 2024 11:26:19 +0000
Days To Display / Load =1, still displays yesterdays data
View Count: 1016
[2014-05-05 13:47:57] |
T44 - Posts: 363 |
Symbol ES, 1 minute chart, Start Time 09:30:00; End Time 15:59:59 New Bar At Session Start = checked When time == 09:29:00 Behaviour - yesterdays data displayed, last bar is the 15:59 bar from yesterday When time == 09:30:01 (first ES ticks have come through) Behaviour - yesterdays data displayed, todays data displayed, last bar is the 09:30 bar from today, vertical scaling very skewed on day like today when price at 09:30 substantially different from yesterdays close Expected behaviour - yesterdays data no longer displayed, only 1 bar from today displayed Does this make sense? The charts are displaying more than the asked for "days to display" as new data comes in. The only way I've found to "fix" is to open chart settings, set days to load to a number other than 1, apply, then set back to 1. The name given is days to display/load but it occurs that this is two different things. It is behaving like "days to load" and appending new data, not "days to display" which would cease displaying previous days data if set to 1. If there are no plans to modify the way this feature behaves, I'd be grateful for any hints on coding a custom study to "refresh" the days to load on the first incoming tick after "Start Time". Thanks. Date Time Of Last Edit: 2014-05-05 13:49:11
[2014-05-05 18:40:59] |
If there are no plans to modify the way this feature behaves, The easy solution is to select Edit >>Reload All Charts. Or Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-05 18:41:51
