Date/Time: Sun, 01 Nov 2026 07:32:13 +0000
retard flux
View Count: 827
[2022-06-24 17:42:37]
User708732 - Posts: 2
bonjour,
j'ai constater un retard de 10min sur les prix du nasdaq.
n'ai je pas le flux en temp réel avec le pack que j'ai acheté?
quel est la solution ?
[2022-06-24 18:41:52]
From Google Translate:
I noticed a 10min delay on nasdaq prices.
don't I have the real-time stream with the pack I bought?
what is the solution ?
If you are wanting real-time data from our NASDAQ TotalView exchange, then you need to go through the Setup Instructions at the following link:
Denali Exchange Data Feed
