Date/Time: Sat, 04 May 2024 02:49:17 +0000
"Replay charts" of two chartbooks at the same time (synchronized)
View Count: 1350
[2014-05-05 11:29:38] |
User52866 - Posts: 13 |
Dear All, I would like to kindly ask you for an advice how to replay charts in two opened chartbooks - meant both chartbooks are replayed synchronized. Thanks a lot & Kind regards K.S. |
[2014-05-05 15:50:16] |
It is supported to start replays of charts in 2 different Chartbooks, but they will not be synchronized.
