Date/Time: Tue, 07 May 2024 06:29:20 +0000
automatically colour area between to hand-drawn horizontal lines
View Count: 947
[2014-05-05 11:07:28] |
Dom7364 - Posts: 257 |
Is there a way to automatically to colour fill in the area between 2 hand drawn horizontal lines?
[2014-05-05 16:07:19] |
No. You will need to use the Horizontal Lines study instead. Refer to the documentation here about this: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#FillingArea Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
