Date/Time: Thu, 15 Jan 2026 08:02:41 +0000
Clear Method Swing Line
View Count: 1093
[2022-06-24 09:20:12]
User964292 - Posts: 2
The Clear Method Swing Line formulas in spreadsheet format provided by Sierra Chart's Technical Studies Reference does not seem to be a downloadable file. If true, can this be corrected?
[2022-06-24 13:39:03]
John - SC Support - Posts: 43987
The file is a standard Sierra Chart spreadsheet. If you are selecting it and it is opening in your browser as gibberish, then that is because your browser is interpreting the extension as a stylesheet.
To work around this, you need to right-click and select Save Line As... and then save the spreadsheet to the Data folder under your Sierra Chart installation folder.
[2023-08-20 21:23:13]
User971805 - Posts: 4
Is there a way to automate this indicator to take trades as the line changes colors?
[2023-08-20 22:51:34]
Sawtooth - Posts: 4308
Here's a simplified spreadsheet version:
=IF(OR(D3>C5,D3>K4),D3,IF(OR(C3<D5,C3<K4),C3,K4))
where this formula is entered in cell K3.
This is taken from this example:
https://www.sawtoothtrade.com/free-stuff-7.html
To get a signal for each direction change, use the formulas in N3/O3 to separate the up/down prices, then use the formulas in P3/Q3 for the signals.
[2023-08-21 02:47:25]
Sierra_Chart Engineering - Posts: 22375
Have a look at this study:
Trading System Based on Alert Condition
Date Time Of Last Edit: 2023-08-21 02:47:33
