Date/Time: Tue, 07 May 2024 20:48:08 +0000
POC on candle chart
View Count: 1650
[2014-05-05 10:15:49] |
Dom7364 - Posts: 257 |
Is there a way to do exactly that, as described, but witout seeing the profile itself, just on a candle chart? http://www.marketdelta.com/blog/wp-content/uploads/ExtendedNakedVPOCs.png |
[2014-05-05 15:52:04] |
No. This is not supported. You do need to display the Volume Profiles as well by using the Volume by Price study.
