Date/Time: Wed, 01 May 2024 21:45:18 +0000
issues with replays
View Count: 328
[2022-06-23 16:00:00] |
User449884 - Posts: 136 |
When Using replays on the DOM, no matter what date i pick, it always opens up to the same price and same price action. like its always the same day whichever date i chose
[2022-06-23 18:18:26] |
John - SC Support - Posts: 31283 |
You have to have the data loaded to go back to a certain spot, otherwise it will start at wherever the earliest loaded information starts. Refer to the following: Replaying Charts: Replaying Chart from Specific Date-Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-23 19:34:11] |
To replay a Trading DOM, refer to: Replaying Charts: Replaying Trade DOM Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
