Date/Time: Thu, 02 May 2024 17:55:29 +0000
Historical 30 Second Opening Range (extended)
View Count: 324
[2022-06-22 13:12:42] |
Mattc55 - Posts: 97 |
Hello, Wondering if there is a way to extend the historical 30second opening range. I have an intraday chart with 5000 days loaded with only the first 30seconds and the IB study that highlights the High and low with a dash / dot, problem is that it does not extend each and every OR to the right where i can then pick it up on another chart with an overlay. the goal is to highlight the old Opening ranges as far back as possible on a lower time frame chart. any help appreciated. thx |
[2022-06-22 17:26:26] |
John - SC Support - Posts: 31324 |
Use the Extend Bar Value Until Future Intersection study and base it on the Initial Balance study to get the lines to extend across the entire chart. Then when you use the Study/Price Overlay base it on the Extend Bar Value Until Future Intersection and be sure to set the Input for Copy Extension Lines from Source Study to Yes. Refer to the following for the Extend Bar Value Until Future Intersection study: Extend Bar Value Until Future Intersection For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
