Date/Time: Fri, 03 May 2024 11:56:38 +0000
Split TPO profile
View Count: 357
[2022-06-22 07:52:55] |
Mustang77 - Posts: 122 |
Hi When i right click on the TPO profile, the "split profile here" option is grayed out, i can't click on it. What's the reason for that? Thank you |
[2022-06-22 08:01:04] |
It depends where you right-clicked. We would need to see an image of the chart and specifically know where you right-clicked. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-22 08:01:20
