Date/Time: Fri, 03 May 2024 11:33:27 +0000
VBP overlapping TPO
View Count: 342
[2022-06-22 01:59:35] |
ScottK - Posts: 43 |
As per the attached image, my VbP study is overlapping TPO study and I cannot figure out why. Help! https://www.sierrachart.com/image.php?Image=1655862950461.png |
[2022-06-22 16:28:44] |
John - SC Support - Posts: 31334 |
We assume you are referring to the VbP on the right hand side and the TPOs that are within that area. The only thing you can do for this would be to lock the fill space such that your bars (TPO profiles) will not be in the area of the VbP. Refer to the following: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LockFillSpaces For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
