Date/Time: Sat, 04 May 2024 18:10:54 +0000
ACSIL order error after update 1132
View Count: 1283
[2014-05-04 22:00:55] |
VF56002 - Posts: 27 |
Suddenly my strategies give me an order error during replay (sim mode) and have no idea why. Backtest also does not work for me but it all worked flawlessly before update ... Alert Manager says: "Alert notification email error: Invalid Account | 2014-05-04 16:56:28" Date Time Of Last Edit: 2014-05-04 22:01:57
[2014-05-05 01:17:01] |
We will look into the Alert Manager error. However, specifically what errors are you getting in the Trade Service Log for orders? Copy and paste them here.
[2014-05-05 07:45:00] |
The strange thing is the Trade Service Log shows no info at all about error. It just stays empty. I am using Rithmic with DDT/Crossland but I don't suspect trading service settings since replay works in the Simulation Mode. Trade window for chart shows "Sim" account selected. Only error I see is one mentioned above when I have alerts activated in my strategy |
[2014-05-05 07:50:49] |
Is this an ACSIL trading system? Or are you using the Spreadsheet Trading study?
[2014-05-05 07:57:12] |
I have found the problem This combination probably caused the error: NewOrderLong.OrderType = SCT_MARKET; NewOrderLong.TimeInForce = SCT_TIF_DAY; I wonder why it worked before update and .. ts log did not provide any error details and alert contained "Invalid Account" error but everything seems to be ok now ... |
[2014-05-05 08:06:51] |
NewOrderLong.OrderType = SCT_MARKET; NewOrderLong.TimeInForce = SCT_TIF_DAY; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-05 22:05:08] |
We have tested the following function and we do not see a problem. Make sure you recompile your code on the latest Sierra Chart version and you are using the updated DLL file. SCSFExport scsf_ACSILTradingTest(SCStudyInterfaceRef sc) { //Define references to the Subgraphs and Inputs for easy reference SCSubgraphRef BuyEntrySubgraph = sc.Subgraph[0]; SCSubgraphRef BuyExitSubgraph = sc.Subgraph[1]; SCSubgraphRef SellEntrySubgraph = sc.Subgraph[2]; SCSubgraphRef SellExitSubgraph = sc.Subgraph[3]; SCInputRef Enabled = sc.Input[0]; if (sc.SetDefaults) { // Set the study configuration and defaults. sc.GraphName = "Trading Test"; BuyEntrySubgraph.Name = "Buy Entry"; BuyEntrySubgraph.DrawStyle = DRAWSTYLE_ARROWUP; BuyEntrySubgraph.PrimaryColor = RGB(0, 255, 0); BuyEntrySubgraph.LineWidth = 2; BuyEntrySubgraph.DrawZeros = false; BuyExitSubgraph.Name = "Buy Exit"; BuyExitSubgraph.DrawStyle = DRAWSTYLE_ARROWDOWN; BuyExitSubgraph.PrimaryColor = RGB(255, 128, 128); BuyExitSubgraph.LineWidth = 2; BuyExitSubgraph.DrawZeros = false; SellEntrySubgraph.Name = "Sell Entry"; SellEntrySubgraph.DrawStyle = DRAWSTYLE_ARROWDOWN; SellEntrySubgraph.PrimaryColor = RGB(255, 0, 0); SellEntrySubgraph.LineWidth = 2; SellEntrySubgraph.DrawZeros = false; SellExitSubgraph.Name = "Sell Exit"; SellExitSubgraph.DrawStyle = DRAWSTYLE_ARROWUP; SellExitSubgraph.PrimaryColor = RGB(128, 255, 128); SellExitSubgraph.LineWidth = 2; SellExitSubgraph.DrawZeros = false; Enabled.Name = "Enabled"; Enabled.SetYesNo(0); Enabled. SetDescription("This input enables the study and allows it to function. Otherwise, it does nothing."); // This is false by default. Orders will be simulated. sc.SendOrdersToTradeService = false; sc.AllowMultipleEntriesInSameDirection = true; //This must be equal to or greater than the order quantities you will be submitting orders for. sc.MaximumPositionAllowed = 10000; sc.SupportReversals = false; sc.AllowOppositeEntryWithOpposingPositionOrOrders = true; // This variable controls whether to use or not use attached orders that are configured on the Trade Window for the chart. sc.SupportAttachedOrdersForTrading = false; //This variable controls whether to use the "Use Attached Orders" setting on the Trade Window for the chart sc.UseGUIAttachedOrderSetting = false; sc.CancelAllOrdersOnEntriesAndReversals= false; sc.AllowEntryWithWorkingOrders = true; sc.CancelAllWorkingOrdersOnExit = true; sc.AllowOnlyOneTradePerBar = false; //This needs to be set to true when a trading study uses trading functions. sc.MaintainTradeStatisticsAndTradesData = true; sc.AutoLoop = true; sc.GraphRegion = 0; // During development set this flag to 1, so the DLL can be modified. When development is completed, set it to 0 to improve performance. sc.FreeDLL = 0; //sc.OnExternalDataImmediateStudyCall= true;//Increases CPU load. Use with caution. return; } //These must be outside of the sc.SetDefaults code block sc.SupportTradingScaleIn = 1; sc.SupportTradingScaleOut = 0; if (!Enabled.GetYesNo()) return; if ( sc.LastCallToFunction ) return;//nothing to do // Run the below code only on the last bar if (sc.Index < sc.ArraySize-1) return; s_SCPositionData PositionData; sc.GetTradePosition( PositionData); if (PositionData.PositionQuantity== 0) { // Create an s_SCNewOrder object. s_SCNewOrder NewOrder; NewOrder.OrderQuantity = 1; NewOrder.OrderType = SCT_MARKET; NewOrder.TimeInForce = SCT_TIF_DAY; //Specify a Target and a Stop with 8 tick offsets. We are specifying one Target and one Stop, additional targets and stops can be specified as well. NewOrder.Target1Offset = 8*sc.TickSize; NewOrder.Stop1Offset = 8*sc.TickSize; NewOrder.OCOGroup1Quantity = 1; // If this is left at the default of 0, then it will be automatically set. sc.BuyEntry(NewOrder); } } Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
