Date/Time: Thu, 02 May 2024 21:17:17 +0000
Upgraded to Pkg10 but only Delayed Data Feed
View Count: 281
[2022-06-21 02:05:59] |
User388297 - Posts: 8 |
Hi Support, When my data feed stopped working, AMP support prompted me to upgrade to your Pkg 10. Both the CQG and SC Data feeds are delayed. How do I fix this back to my real time feed? |
[2022-06-21 05:28:13] |
There are two things you can do. Go back to version 2393 or earlier. Instructions: Software Download: Software Rollback Procedure Or activate the exchanges you require here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-21 05:28:23
