Date/Time: Sun, 01 Nov 2026 08:24:25 +0000
side by side number bars
View Count: 676
| [2022-06-19 13:50:46] |
| pampolpops - Posts: 12 |
I am trying to post side-by-side number bars for the same period showing a standard mixed profile + a split profile, how do I change the column settings to show both with enough spacing?
Date Time Of Last Edit: 2022-06-19 13:51:03
| [2022-06-20 14:21:27] |
| John - SC Support - Posts: 48377 |
It looks like you have the first column set to have a Background Type of ...Across All Columns. If this is not intentional, then you would want to change this so the first column information is just in the first column. Refer to the following: Numbers Bars: Numbers Bars Background Types Then it is just a matter of scaling the chart as you need it. Refer to the following information: Numbers Bars: Scaling a Numbers Bars Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
