Date/Time: Wed, 01 May 2024 14:47:13 +0000
question
View Count: 986
[2014-05-04 13:58:25] |
User38228 - Posts: 1 |
Dir Sir-Madam, I need your help. Where I can find a tick data? In older Sierra , they called - SC Historical Intraday Futures Data directory. Thanks so much for the answer and your hepl. Mrs. Brokeš |
[2014-05-05 03:58:21] |
You need to use the Sierra Chart Historical Data Service: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html This service now provides historical tick by tick data for major futures contracts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
