Date/Time: Mon, 06 May 2024 01:11:59 +0000
Chart not attached to a chartbook
View Count: 396
[2022-06-16 12:45:05] |
User447431 - Posts: 29 |
Hi.. I currently have 2 chartbooks tabs, one for pound and other for gold Each chartbook has 7 chart tabs each... but two of these tabs seems not to working properly Daily TPO for example, when im on the pound chartbook its ok....... but when I move to gold chartbook the daily TPO POUND still above the gold chart.. picture attached to make it clear What I want is simple.. when im on pound chartbook I want to see only pound charts, gold chartbook only gold charts.. |
[2022-06-16 12:59:29] |
Go to that chart and uncheck this command from the Window menu: Window and CW Menus: Window Always Visible (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
