Date/Time: Sat, 27 Apr 2024 22:17:28 +0000
this suddenly starting popping up
View Count: 267
[2022-06-16 12:29:37] |
User849502 - Posts: 299 |
this won't stop. It just started about 20 min ago. What is it please, and how can I stop it. thanks |
message.PNG / V - Attached On 2022-06-16 12:29:27 UTC - Size: 244.49 KB - 86 views |
[2022-06-16 12:33:50] |
This indicates a connectivity problem that you are having from your side to at least two of our servers. Could be a temporary problem with your ISP or somewhere else and it would eventually clear up. Otherwise, refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#NetworkCommunicationOrServerProblem It is not a Sierra Chart server problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
