Date/Time: Mon, 06 May 2024 17:41:03 +0000
Volume At Price Threshold Alert V2 - LAYERS/HIDDEN
View Count: 441
[2022-06-15 14:48:47] |
topdowntt - Posts: 2 |
I use this study to plot imbalances. The plots always end up behind some of the number bar backgrounds (not just on this particular combo + I have tried 'Move Up') the become unable to view when the chart/price gets stretched Can you tell me where I am going wrong? or add a fix please. thank you! |
Attachment Deleted. sierraQUntitled-1.jpg / V - Attached On 2022-06-15 14:42:57 UTC - Size: 28.46 KB - 105 views Screenshot 2022-06-15 at 15.43.52.png / V - Attached On 2022-06-15 14:44:49 UTC - Size: 178.57 KB - 97 views |
[2022-06-15 19:06:29] |
John - SC Support - Posts: 31401 |
Make sure the Volume at Price Threshold Alert V2 study is listed below the Numbers Bars in the list of studies. That should take care of it. But, you might also want to consider adding a second column to the Numbers Bars which has the background coloring and then remove the background coloring from the first column, to help make it easier to see the Volume at Price Threshold Alerts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-15 19:53:24] |
much appreciated. positioned it below and now fixed. thank you!
