Date/Time: Sat, 12 Jul 2025 00:57:21 +0000
[Programming Help] - Programming - How to Buy/Sell Exit 2*ATR
View Count: 590
[2022-06-14 21:25:04] |
GG - Posts: 20 |
System is designed to enter buy if gap from previous day's high to current day's open is larger than 2*ATR. System enters sell if gap from previous day's low to current days open is larger than 2*ATR. I am doing this by referencing OHLC (References Days Back: 1). BuyEntry =(J16-ID1.SG2@3)>(ID2.SG1@3*2) BuyExit (Sell) =OR(AND(J8 > 0, ID0.SG4@3 <= J9-(ID2.SG1@3*2)), AND(J8 > 0, ID0.SG4@3 >= J9+(ID2.SG1@3*2))) SellEntry =(ID1.SG3@3-J16)>(ID2.SG1@3*2) SellExit (Buy) =OR(AND(J8 < 0, ID0.SG4@3 >= J9+(ID2.SG1@3*2)), AND(J8 < 0, ID0.SG4@3 <= J9-(ID2.SG1@3*2))) The Problem: When replaying past days, Daily Open (J16) = 0. So it sends a SellEntry through every bar. I'm not sure how else to reference Daily Open when my OHLC is set to previous day? Thanks for your help. |
[2022-06-15 02:26:21] |
Sawtooth - Posts: 4238 |
You could add another instance of the Daily OHLC study, with Reference Days Back set to 0.Note: When referencing column J in Formula Columns, use an absolute reference: =OR(AND($J$8 > 0, ID0.SG4@3 <= $J$9-(ID2.SG1@3*2)), AND($J$8 > 0, ID0.SG4@3 >= $J$9+(ID2.SG1@3*2))) |
[2022-06-15 17:21:15] |
GG - Posts: 20 |
Thank you, that worked perfectly. Now the problem I am running into is the ATR. Is there any way to reference the ATR but only at 9:30? i.e my BuyEntry isn't triggered at open but since I need the BuyExit to trigger during trade hours, my Chart Start Time is 9:30 and End Time is 17:00. So if ATR slowly decreases throughout the day, the BuyEntry is triggered mid day. BuyEntry: =(ID6.SG1@3-ID1.SG2@3)>(ID2.SG1@3*2) |
[2022-06-15 18:03:51] |
If you want to reference the ATR's level as it was at 09:30:Create a persistent variable of the ATR*2 at 09:30, like this, e.g. in cell P3: =IF(FRACTIME(A3)=TIME(09,30,0),ID2.SG1@3*2,P4) If you want to only signal in the bar that is timestamped 09:30: =AND(FRACTIME(A3)=TIME(09,30,0) , ID6.SG1@3-ID1.SG2@3 > ID2.SG1@3*2 ) |
