Date/Time: Sun, 05 May 2024 13:34:24 +0000
CBOT Delayed Data Problem
View Count: 475
[2022-06-14 20:06:05] |
User306477 - Posts: 4 |
Hello, I have a problem with the CBOT data. These are displayed to me late, although I have subscribed to the Denali Exchange Data Feed CME / CBOT / NYMEX / COMEX Exchanges. The other markets are not displayed delayed. I have attached a few screenshots for you. I hope you can help me. Thanks in advance |
Screenshot 2022-06-14 215806.png / V - Attached On 2022-06-14 19:59:11 UTC - Size: 65.33 KB - 97 views Bild_2022-06-14_220106788.png / V - Attached On 2022-06-14 20:01:05 UTC - Size: 852.04 KB - 101 views Attachment Deleted. |
[2022-06-14 21:05:15] |
John - SC Support - Posts: 31362 |
Soybean Oil has odd trading hours. Refer to the information here: https://www.cmegroup.com/markets/agriculture/oilseeds/soybean-oil.contractSpecs.html Most likely, you are just seeing a period where they are not trading. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-15 04:27:40] |
In the Volume Profile Weekly, the Value Area High and Low or the Point of Control are displayed incorrectly. The problem is not only with ZL but with almost all grains ZC, ZW, ZS, ZM, and ZL after the market close. When the market is open the data are not delayed. |
[2022-06-15 06:30:02] |
Refer to:Time Price Opportunity (TPO) Profile Charts: Incorrect Value Area or Point of Control Values (Incorrect Value Area or Point of Control Values) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-15 06:30:15
[2022-06-15 20:03:21] |
I have matched the data and studies with another user. We have the same template, data provider, Denali datafeed, everything is the same. However, we have different Value Area High and Low in the volume profiles for the ZW and ZL.
[2022-06-15 20:21:28] |
Can it possibly be due to the differences between computer and laptop???
