Date/Time: Wed, 08 May 2024 21:49:10 +0000
Chart Studies-Studies to Graph-Name
View Count: 1609
[2013-04-26 22:47:47] |
sandpiper4011 - Posts: 17 |
Support: I am using version 967 In Studies to Graph - Save Studies As Study Collection Name: Box - problem Each study requires a name, sometimes after modifing the study the name "Box" is blank. ie: when I return to the Study the "name" is often missing in the "Name: - Box". I then have to reenter the name to close out the study. Must be doing something wrong or there is a box in the software that I have missed checking Suggestions please. |
[2013-04-26 22:56:11] |
If you do modify studies, then the the Name edit box will be blank because the study collection has changed and it cannot be reliably identified as to what study collection it is any longer, but you can select the name from the Name list box. It is within that list.
