Date/Time: Tue, 07 May 2024 21:33:29 +0000
Nasdaq Total View Depth
View Count: 450
[2022-06-13 16:01:52] |
Ben A - Posts: 123 |
Hi, I signed to Nasdaq total view as I wanted the depth data for stocks. I do not seem to be getting more than one level of depth - I have left my depth setting as maximum levels of depth. Is there anything I need to do to turn on the depth data? I have read the instructions here How to Use New NASDAQ Total View Data Feed It does seem to be working for QQQ but not SPY, AAPL etc. It displays depth but only where price has been, not extended beyond price. Same settings as QQQ Many thanks, |
[2022-06-13 16:51:42] |
John - SC Support - Posts: 31440 |
In order to get the data from the NASDAQ TotalView, you need to have the suffix of -NQTV on the symbol. Otherwise, it will be pulling the data from the Sierra Chart Exchange Data Feed, which does not have the Market Depth data. For example, IBM would need to be entered as IBM-NQTV to get the NASDAQ TotalView data for IBM.
[2022-06-13 19:04:10] |
Thanks John, I do have that. So Spy I have SPY-NQTV loaded and only 1 level comes up. QQQ-NQTV I have full depth. I have 1000 level of depth for both. QQQ looks good: https://www.sierrachart.com/image.php?Image=1655146886135.png SPY https://www.sierrachart.com/image.php?Image=1655146983343.png Thanks, |
[2022-06-13 19:10:54] |
OK, I stopped the feed and then restarted and SPY came online but not AAPL. I repeated that process a few more times and then AAPL kicked in. Strange. Hopefully its just an issue with initial start-up with the service.
[2022-06-13 19:17:14] |
You should not be having any issue such as you reported. But, if you see this again, then take a look at your Market Depth window (File >> Open Market Depth Window) and see how many levels of data are showing up there.
[2022-06-13 19:19:01] |
Thanks John, will do, will keep an eye on it. Many thanks
