Date/Time: Sun, 05 May 2024 12:47:58 +0000
Download Allowed Users data in CSV format
View Count: 403
[2022-06-13 11:14:01] |
ticinotrader - Posts: 378 |
Dear Support, Can you please consider adding the function/option: 'Download in CSV Format', to the Manage Cutom Studies Access >> 'Sierra Chart Custom Studies Access Control Panel' 'Allowed Users' section? It would be very helpful to be able to download that (all columns) data in spreadsheet (csv) format for further processing. Thank you in advance. |
[2023-09-05 16:53:16] |
Dear support, Would it be possible to add this feature to the Allowed Users section? Thank you. |
[2023-09-05 21:34:50] |
Sierra_Chart Engineering - Posts: 14230 |
We will look at adding this capability.
[2023-09-05 22:26:53] |
Sierra Chart - Max - Posts: 5605 |
You can get the list of users using the Web API. Sierra Chart Website APIs: Manage Custom Studies Users You can use a tool such as curl or postman to manually use the api https://www.postman.com/product/what-is-postman/ Let us know if that will work for you. Sierra Chart Support Date Time Of Last Edit: 2023-09-05 22:27:20
[2023-09-06 11:41:15] |
Thank you, This looks exactly what I need. curl will work very well.
