Date/Time: Sun, 28 Apr 2024 04:57:38 +0000
toggle on/off certain chart drawings from one
View Count: 278
[2022-06-12 22:14:00] |
sxmiali - Posts: 4 |
hi all im looking to add buttons to my control bar or any other way to toggle on/off some drawings instead of "hiding all other" im looking for hiding only from one hour chart but keeping all others etc
[2022-06-13 10:51:07] |
The only command available close to this is this one: Chart Menu: Hide Chart Drawings (Chart menu) We will be developing the ability to control what time frames, chart drawings will be visible on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
