Date/Time: Tue, 07 May 2024 14:21:14 +0000
Maximising and minimising multiple chart windows with one click?
View Count: 382
[2022-06-12 18:35:42] |
bootsy - Posts: 63 |
Hi there, I have a variety of detached charts within a chartbook. They float around and I can move them where I want/resize them etc and it's great. What I would like to do is have them all disappear (or reappear) with one click of a button. At the moment you press the minimise button and just one chart disappears which is not what I'm after. Any help would be greatly appreciated. Regards, Bootsyjam |
[2022-06-13 14:35:24] |
These charts are saved as part of a Chartbook: Chartbooks (Workspaces) And then you could just close the Chartbook or switch to a different Chartbook to make them be hidden and then go back to the original Chartbook to restore them: Chartbooks (Workspaces): To Switch Between Loaded Chartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
